It will not come on when I set it on wash.
It will fill with water if I put it on rince.
The delicate cycle will work, hit and miss.
Plese help.
I need to know what part torder and at least a hint as to where I can find it to try and replace it. thatk you
Since it will go through a complete rinse cycle, that suggests there is no mechanical problem and that the timer is at fault.
Here is the part
I would call in the order, and have your model and serial numbers with you as Maytag sometimes changes parts for the same model.
