Washer fills up and then stops, doesn’t not continue cycle. sometimes can manually advance the dial to rinse and will pump out, fill back up and stop, will not advance any further.
Hi Sharbear
Sounds like a timer issue. There are several listed for your model, with widely different prices so I would call APP and see what they say.
Good luck.
Call in your order and give them your serial number, they should be able to get you the right one.
