Maytag Washer
My top loading washer wouldn’t spin out the water and now it won’t even agitate. Any help would be appreciated. Is there a belt somewhere?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MAV208DAWW
Here is a service manual, wiring diagram ans some tech sheets which may be relevant
http://www.servicematters.com/maytag_library/docs/16026502.pdf
http://www.servicematters.com/maytag_library/docs/16027498.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0143-B.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0113-S.pdf
Thank You so much. I appreciate it. Now I will see if I can track down what the problem may be.
Drum turns on but no heat. circuit breaker, fuse, vent pipe everything is ok. noticed heating element is not coming on. thinking of chnging it, want to know shoud I check the thermostat and cut of switch before I change the heating element?
