My washer fills up with water, but, now it doesn’t go through the cycles, ie; wash cycle, rinse cycle, spin cycle? Would the problem be the control panel switch?
The first thing I would do is check the lid switch (#3 on the [B]wiring diagram[/B] for continuity according to the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=49072&diagram_id=673618).
- The lid switch assembly AP4008646
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=49072
