Maytag washer
My washer will not stop running water in even with the load setting on low, I have to turn the water off to make it stop running. Then turn the water back on to finish the washing process. I have pushed every button possible and the water will not cut off. Help! Thanks
does the water run with the machine turned off? If so you have a bad water valve. If it just continues to run when the washer is turned on, you either have a bad pressure switch, or there is some buildup of gunk where the pressure switch attaches to the tub.
