Washer water runs constantly.
Washer water is not stopping unless the tub is full. The water will stop if the tub is full. The washer runs through the cycles as best I can tell. The water stops if the tub is full the proper height. The water runs though through the spin cycle and at the end of the wash the tub fills with water and then stops.
I have already replaced the pressure valves. I also have an "Extra Rinse" rocker switch that stays in the on position. I am not sure if that is normal, but it will not stay in the off position.
Right now I am stuck on it still being the pressure switch, even though it stops filling ever time at the right height, or the timer, or that Extra rinse button. If you have any information that would help specify the exact issue I would appreciate it. I am on the verge of ordering all the parts and seeing which one fixes it.
Jim
Try replacing the water level switch. If that does not fix things try replacing the timer. If you buy parts from this site you can return the ones you don’t need.
