My dryer tumbler stop turning so i assumed it was the belt. I removed the tumbler ant found the belt intact with a burn mark were it had rested against the exhaust tube, i figured it stretched out and became lodged against the tube. I checked the motor drive to make sure it wasnt frozen up and found the pulley that moves the belt was loose. Does this mean I need toreplace the motor, it doesnt look as if the pulley can be tightened.
Related topics
Maytag Dryer Loose Motor Pulley | 1 | 6154 | December 30, 2010 | |
Maytag Dryer quits tumbling after a few minutes | 5 | 2395 | July 29, 2009 | |
Maytag Dryer Drum Won't Turn | 17 | 25997 | June 23, 2012 | |
belt slipping on motor pully | 2 | 3028 | January 14, 2013 | |
troubleshooting broken dryer belt | 2 | 2036 | December 18, 2009 |
