4/5 yrs old. Fridge and freezer stopped cooling. When display was touched, all lights would blink. Replaced main control board. Programmed fridge with fridge code, fridge is now cooling. Set freezer at 0 degrees, it is holding at 0. Set point for fridge at 34 degrees fridge temp holds at about 20 degrees, set fridge temp for 46, fridge temp holds at 20 degrees. Note: The display set points do not change. Display set points are 0 and 46. Freezer temp is 0 and fridge temp is 20 degrees. Note: The display set points do not change. Display set points are 0 and 46. Freezer temp is 0 and fridge temp is 20 degrees. Should the display show actual temp in freezer and refridgerator or does it always show selected temp number ?
Related topics
Maytag Refrigerator Display Stuck on -1 and 37 degrees | 1 | 1244 | June 12, 2013 | |
Refrigerator Freezes Food | 1 | 1194 | July 5, 2010 | |
maytag frige temp display | 1 | 896 | January 7, 2010 | |
Maytag MZD2669KEW Refrigerator | 1 | 77 | April 14, 2020 | |
Fridge not cooling enough, but Freezer is fine | 1 | 127 | August 19, 2019 |
