No weather or power problems. I can program the keypad. Key pad and timers do what there supposed to. The problem is nothing kicks on to cook the food. There is no loud noise when I hit the start button. the time counts down and beeps at the end, but nothing happens as far as cooking. there is an inital clicking sound immediately after I push the start button. The turn table does not turn either.
You may want to start the troubleshooting from the secondary interlock switch (the upper door switch). The easiest way to access the door switches is to remove the microwave outer case.
Are you suggesting that I should replace the secondary interlock switch because the information I have supplied says that switch is most likely the problem or is there a way I can test this switch?
Are you suggesting I replace the secondary switch, because the information I supplied implies that switch is most likely the problem or should I test the switch? How?
Every time when you do the continuity test, the wires should be disconnected. The microwave MUST be unplugged.
I would just replace the switches. Especially because the substituted switch is absolutely inexpensive. This switch has three terminals compare to the OEM switch which has just two. You have to carefully break off the terminal marked NC.
According to the diagram, the secondary interlock switch in this model is the bottom switch. So if you replaced only the upper switch, replace the bottom switch too.
