The plastic frame of the door broke through in the front, bottom. This caused the glass to drop. I’m going to replace only the plastic frame, and ordered the part. However, it comes with no instructions on how to remove the old door.
I’ve taken off the obvious screws around the door, but it still hangs by the hinge. I don’t want to force anything, or I’ll end up buying the $170 entire door, rather than the $40 frame.
Any help in where I can locate instructions to take the door off, then apart, and replace will be GREATLY appreciated.
Thank you.
