Microwave Door
Whirlpool microwave door. mh1150xmb1
the plastic frame below the handle and the handle cracked and pieces broke off. I have a new door from you. I removed the outer plastic frame on the old door by removing 3 screws on the inside edge of the door. the inner door is still attached to the microwave. The new door does not want to seperate easily and i do not want to break it. can i replace the whole door or what is best and easiest. i would have thought instructions would have come with it when you spend $240 on a door.
thanks
Craig
Hi Craig,
You don’t have to take the old or new doors apart. Remove the top grille and the screw secured the top hinge.
