approx 2 weeks ago our dryer quit heating. i have tested the thermo fuse and the two fuses on the heating ele (i may have the terms wrong sorry) originally i found bad continuity on the heating element itself and have replaced it, i also replaced the two fuses from the element and the one above it and it still does not heat… i’m at the end of my rope please help!
I just had the same problem with my dryer, it’s a different model. It ended up being a thermostat. Mine was located on the same housing that the element was in, up above the element on the actual housing. Hope this helps.
— Begin quote from dave3795;595886
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ler7646eq2
See the attachment for your wiring diagram.
[COLOR="DarkRed"]
i also replaced the two fuses from the element and the one above it[/COLOR]
Not sure I understand the following. The parts breakdown only shows 2 parts near the element.
One is a thermal cut-off (fuse) and the other is a high limit thermostat, so I am not sure what the third device is.
Did you check the replacement parts with a meter before installing them?
Start by checking your power to the unit. The motor and timer run off of 120 volts but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next unplug the unit. Set the timer to mid scale on a heating cycle and check across Timer switch 2. It should be 0 ohms.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
