I replaced a broken motor coupler on my washer. I put it all back together and the motor isn’t working at all now. Before I replaced it the motor worked fine. I can also still spin the agitator both ways.
If the motor makes no sounds at all, I would check for a partially seated plug on the side, or a bent/pushed out pin.
