my washer will not spin or aggitate but will fill and drain and i just replaced the coupler a month ago i turned on the washer and watched under there and nothing was moving not the coupler and it makes a loud grinding type noise
If your machine will drain then the motor is operating. Take it apart and inspect the coupling close up.
— Begin quote from sidfink43;192669
you were right the coupler was cracked… why it did that being new i dont know but ill put another new one on thanks alot
Well, it is unusual to have a second break, but the coupler is the weak spot, and it is designed to be that way so the motor or transmission is not damaged.
Glad you got it fixed, thanks for the update.
