Motor not turning in spin cycle
Well I left a message earlier for help in diagnosing a problem with a Frigidare washer. Might have been a little perplexing, so I am gona narrow it down. I took the burnt belt off, so what I need to do is figure out why the motor isn’t running in spin mode. The agitator works, timer goes through all cycles, water is going into machine properly, but when timer goes into spin mode, no motor action. So, I need to figure this out. Any one know what I need to check, I think it may be the centrifical switch, could be motor, but I don’t know how to check it. Or it could be a number of problems. Also, is the motor suppose to reverse direction on spin mode, from what I have read, the whole case on transmission is suppose to turn in spin mode, that kind of makes me think it might be the centrifical switch, but I am not sure how to check that, is the centrifical suppose to be inside the motor or in the motor switch, if the motor has a switch. Well, any help appreciated. Thanks!
There are a couple things to check…
  1. check lid switch for continuity…
  2. power to motor fm timer
