So the stupid thing all of a sudden quit doing anything. Wouldn’t hum or run or heat, so I took it apart. I cleaned it all out and something I read said to see if the motor switch was stuck open so I unscrewed the two screws holding it to the motor and the stupid thing fell apart. Wasn’t sure how the wires and terminals went back in it. I thought I figured it out and I put it back together. Now when i push the start switch the motor hums but the drum won’t spin. I disconnected the drub and belt and pushed the start button and the motor spins. However, When I let go of the start button it stops. Any clues? Thanks in advance.
Related topics
Kenmore model 77902791 has trouble starting | 0 | 1299 | September 19, 2011 | |
dryer motor buzzing not starting | 3 | 1998 | May 2, 2013 | |
Motor bad or just belt? | 2 | 585 | May 11, 2016 | |
Dryer humming when starting but drum will not turn | 1 | 6011 | November 3, 2009 | |
Kenmore Dryer wont start | 3 | 1888 | November 23, 2009 |
