Mr.
My front left large cook top element is not always controlable. When the
control knob is on low the element is cooking on high. I have to turn it
off and back on to control element again. Sometimes this works and
sometimes it doesn’t. Could the control switch be bad or might it be
in the circuit board? Everything else functions properly. If it is the
switch, is the part no. AP3095444?
William Fath
29 Steinbeck Ct.
O’Fallon, MO 63366-7455
636-9788-8308
woolywilly42@aol.com
It sounds to me like you’re on the right track. I’d say it is the switch and the one you have picked out is for the large 8 inch element. So all you need to do is order it and replace. Good luck.:slight_smile:
