Burner or control? Super capacity 365 electric
Left front heating element does not turn on. Turning on the control knob lights the power light next to the control knob but the element does not warm and the hot surface light on the cooktop does not come on. Should I suspect the control, the element, or something else entirely? BTW. All other elements are working fine.
Thank you
Will
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RF378PXGZ0
[COLOR="Blue"]
Should I suspect the control, the element, or something else entirely?[/COLOR]
Probably either the element or the control although there is always an outside possibility of a bad connection/wire.
Remove the element and check it with a meter. If it checks OK replace the control.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
