My Matag DW will not fill with water I filled it fm the sink once and it did fine but the last time it did not do a rinse and I had soapyness
Hi.
With toe panel removed check if the float (located in the front left corner) is not stocked in upper position and see if the water level switch is OK.
Next, using the multimeter, with timer set for "fill" check for 120VAC at the water inlet valve contacts.
If there is the 120v to the valve and the float switch is closed - replace the valve.
The float 99002363
The water level switch 99002560
The water inlet valve 99001359
Her are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45312
Thank you. post the results.
Simon.
