I have broken the supply hose that goes into the freezer door through the hinge.They say they do not have a replacement.They say you have to replace the whole door.The door cost $500 That seems alittle extreme.Does anyone know how to fix this issue without buying a door.Its a $2 plastic hose for gods sake.I am even thinking about cutting a hole on the inside of the door,repairing the hose then patching the hole.I don’t know if that is the right path
Related topics
Water Hose to Dispenser Broken at Bottom of Door | 3 | 140 | September 1, 2020 | |
Water Supply Hose is Leaking | 1 | 1926 | June 23, 2011 | |
how to replace supply line to water dispenser | 1 | 1881 | February 5, 2011 | |
Freezer Door Replacement | 1 | 1223 | February 1, 2010 | |
I have a water dispenser leak inside the freezer door | 1 | 644 | January 10, 2015 |
