Need advice for removing tub nut - Amana ALW432RAW
Need some advice for removing this seal hub so I can remove the outer tub and replace the seal/bearing. I have the proper spanner wrench. Here is a pic that I found online that illustrates what I’m trying to do:
Photo link
There is nothing below that I can block off to keep everything from spinning. Is there another way?
Thank you!
Mike
