The washer was leaking under the tub on the shaft. It has become very noisy in the spin cycle. From previous posts, it appears the bearing is bad and the seal needs replacing. I have it broken down to the lock nut removal but have been unable to break it loose or remove the lock nut spline insert. Any suggestions?
Related topics
Need help with Amana cloths washer | 0 | 1271 | July 12, 2008 | |
Amana washer very loud bearing noise during spin | 1 | 1080 | July 29, 2013 | |
amana washer leaking at tub seal | 1 | 2328 | August 14, 2008 | |
Need advice for removing tub nut - Amana ALW432RAW | 1 | 368 | May 28, 2017 | |
Amana ALW480DAW bearing and seal repair | 1 | 1624 | August 17, 2017 |
