I was wondering what is the best way to access and replace the ring split (wh02x10265), tub bearing (wh2x1197), washer hub (wh2x1199), bearing tub (wh2x1198), and seal tub (wh02x10032)? I’ve been looking for a repair manual to try to figure out as such, but I am unable to find one. Could someone please tell me the best way to get to these parts? I have the front panel off. Should I remove the tub to access it from the top or can it be accessed from the bottom? Any assistance would be greatly appreciated. Thank you.
Eric
