Has A F1-8 Error…
I Replaced The Electronic Control Board Still Has Error…
I Am Able To Cook Up Top But Cant Get The Oven To Function Please Help. Thanks
Has A F1-8 Error…
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JDS9860AAB
Here is the tech sheet and manual
http://www.servicematters.com/maytag_library/docs/16026780.pdf
http://www.servicematters.com/maytag_library/docs/16026016.pdf
Error does come up as a shorted key on the keypad (Item 2 in Section3).
But the fix section says to check for opens so I am not sure that it may also be an open key. You may want to try the below on the keypad.
Bit of a long shot but worth a try.
If it does nothing then I would check the individual keys at the pin-outs/ribbon cable (see the tech sheet). If you find a shorted one then you know for sure that the keypad is the problem.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. You may have to use this procedure on the keypad ribbon cable, depends on the type of connectror used.
There is a good STICKY at the start of this forum about it’s use
