Help!!
I have an LG WM0642HW and it is roughly 10 years old. When I run it through a normal wash it stops just before the spin and drain cycle. The drum just sits and it sounds like a grinding noise.
I removed the rear cover and checked the bearings. The seals are still good and there is no rust residue in the rear of the unit.
I ran a diagnostic test by pushing soil level and spin speed and then powered up the unit. The test stops with a blinking nE code and doesn’t process any test at all.
What could this be? I appreciate your help.
