New control board does nothing but beep
Just replaced the control board in my washer because of an E43 (control board problem) code and when I plug it in, it immediately starts beeping and the right (5) led lights flash 9 times. It does this non stop and even unplugging it will not clear it. It also will not go into diagnostic mode nor will it respond to any button pushed at all. I’ve rechecked all the connections and wires and everything is good.
Hi.
If you are sure that the installation is correct - get another control board.
Simon.
Simon,
Got the new board and installed it. Machine works perfect now. Thanks for the quick response and input.
DZ
It’s my pleasure.
Simon.
