I just replaced the Control Panel I got from this site and now the OVEN GAS burners will not ignite (broil or bake) I do not see the GLOW of the ignitor. The ignitors for the top burners work, as do the controls (you can hear a relay "click" but no power seems to go to the ignitors, even the convect fan come on.) no error codes, the panel seems to think it is working.
This was NOT why I replaced the module, the stove / oven was working, unitl I slightly fried the panel from the back burner using a 2 burner skillet and disfigured the plastic from membrane.
The part I receieved is a Whirlpool and looks a little more modern on the front, but all the back components and wiring is exactly the same. The unit came right up when powered on and seemed ok.
