Previously posted about a problem that I repaired with a new gas valve. Now the oven/broiler will light once and stay lit for 10-15 seconds on go off not light again unless I unplug the range turn the gas off then plug it in and turn the gas back on. Then the whole process repeats its self. Previously the oven/broiler would not even try to light. Found the ohms on the broiler side of the gas valve was 0 and the oven side was 198. But like I said the valve was replaced. Now what?
the same problems and more. I called a repairman and he had absolutely n o ideas. He basically admitted he was guessing. Let me know what you find out.
Hi James. Wondering if you ever got to the root of the issue. My oven burners do exactly the same thing.
