Oven and Broiler Won't Light
Cook top burners light and function fine. When bake (or broil) is selected, there is a click and the gas to the bake (or broil) burner turns on (gas can be both heard and smelt) then the burner ignitors spark 3 times and then the gas shuts off. The bake (or broiler) ignitors never spark. The bake (or broil) burner will light while the burner ignitors are firing if a torch is used and the gas will stay on. I replaced the bake ignitor to see if this was the problem but this did not help. Resistance on gas valve checked at 198 ohms bake/common 195 ohms broil/common.
What would be the next thing to check?
