no agitation
My Maytag Atlantis was making a screech after it went through the spin cycles. Now it doesn’t agitate at all. I can hear the motor go through it’s normal process. Could some one tell what’s wrong ?
THANKS
Remove the front panel and check the belt. Check the thrust bearing (#3 on the [B]Service Manual as described in the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=660426&&model_id=47859).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=660426&&model_id=47859
