When I try to set temp for oven or broil - the clock display lets me pick the temp (oven) then goes blank for a second then goes back to the clock. Same if I chose broil.
Urbanrover, If you can select a cycle and temperature, and have no error codes(F1,F2,F3, etc.) Then the issue is in the ERC/Clock
AP2970621
The eeprom in the clock is not "seeing" the relays close or voltage passing through the circuit, so it misinterprets the input and reverts back to the time of day mode.
Thank you for your prompt reply.
— Begin quote from urbanrover;802772
You’re welcome !!
Good Luck, and Thanks
