no digital display or oven heat
I have fairly new maytag range and have lost display and oven. Range top works well. Have checked power source and is correct at power block. I suspect abad IO board but was not sure if any fuse or safety would stop display from lighting. wire diagram was not readable. Any help would be great.
Most likely the problem is a bad control board. There are no fuses.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1333581&&model_id=5170866
