no digital display
hello, i have double wall oven that has a digital control panel that does’nt work at all. I know the oven is getting power because when you open the doors, the light inside comes on, but the digital display panel above the oven is totally dead. You can’t press any buttons and there are no lights on the display at all. what can we do to fix it?
DOUBLE CHECK BOTH circut breakers(turn them off-then back on) If this does not work, Replace The control board!!!
