I have a whirlpool electric dryer that does not heat. Model# LE7680XSW1. I have continuity in thermal fuse, the cutoff thermostats (both bottom & top) and the other thermostat below the thermal fuse. The "ring" cycle thermostat (whirlpool part # 61894) (25 on the bulkhead parts diagram) attached to the thermostat below the thermal fuse does not have continuity. I tried jumpering this and still did not get heat. I checked for continuity in the heating coil, and have it, both at the terminals and across the coils after the ceramic insulators. Oddly enough, when the dryer runs, I get voltage through the coils but no heat. (Am I tripping? - how does that work?) The voltage from the front wire on the coil (front is front) is about 28v and the voltage on the other wire is 110v.
I’m not sure how old the dryer is. When I opened it up, the whip was bad. I replaced it, and checked power. left to right - 110v - common - 110v. 220 across L1 & L2.
Am I checking the cycling thermostat correctly? Can I get voltage (and continuity) across the heater coil without heat?
Should I look at something else?
