No Heat
I have a Kenmore 90 series dryer that hasn’t any heat. I have checked the continuty of the heat element, the thermal cutoff and the other device on the blower cover. Al tested ok. What next??
First test to see that you have 120v coming to each side of the connection block.
If that is ok, there are 4 thermal fuse/thermostat devices listed for this model, you need to check all four.
If all this checks out you will need to study the wiring diagram for your machine and see if you can trace the problem.
Good luck.
