My dryer won’t make heat. I have replaced the heating element, the Dryer cycling thermostat, the hi-limit thermostat, and the Dryer Thermal Fuse. It still does not create heat. Please help.
Sounds like you have a bad timmer otherwise it should have worked if all your parts are good
Have you checked the power to the unit?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
On this unit the heating element and the timer motor run off of the 240 volts. So if you put the unit into a timed dry mode and start it and the timer does not advance then odds are high that it is a power problem.
Could also be the centrifugal switch on the motor that connects in the heater/timer/240 volts.
