I replaced the heating element and thermal fuse but still no heat. Any suggestions?
These are the parts that can potentially affect your heating system. Before throwing parts at the problem, you should check the power coming to the dryer.
You need to see 240VAC at the outlet (120V from each of the hot legs to the ground). If the outlet is good, look for the same at the terminal connections to the dryer. If you don’t have that at the outlet, try flipping the breaker off then back on a couple times, deliberately.
If the poweer checks out good, a good place to start diagnosing the power loss is the timer.
AP3132867AP3131939AP3094244AP3131941AP3094254AP2976233AP3136147AP3037944AP3094245
