no hot water
i have no hot water or warm water. I have changed the water intake valve and the selector switch. If I switch the connections on the water valve i get all hot water and no warm or cold water. The water lines are on and open. Any other parts to check?
If you have replaced the water valve assembly and the selection switch then the timer is likely the problem. Before you replace it check the wiring between the switch and the timer, and remove, clean and reseat the connections on the timer.
I have read where my machine has an electronic water temperature control board. Do you think that could possibly be a problem also. I did replace the timer about a year ago. I will certainly check the connections. The funny thing is that I can get some warm water if I put the water selector switch between hot and warm. It gives some warm water but then it gets back to cold.
THanks
I could not tell if that model has the board, but if so then it is a good candidate for the problem.
