No ice water, ice-maker ok though
My Kitchen-Aide fridge, KSRB25QABL10, no longer dispense ice water thru the front door dispenser. The icemaker is working just fine though. Any suggestions as to what has gone wrong? Is it a DIY repair? Can’t afford to have a repair guy come out. What parts would I need.
:confused:
The water line could be frozen.
Down at the bottom of the fridge, i removed plastic access panel, noticed a water line connection, so loosened it, and pressed the the water dispenser lever, no water came out. So I’m thinking the value?
Could be the valve or the line inside the freezer for the reserve has frozen. You could disconnect the line at the water inlet valve and test it again like you just did.
Meant line inside the refrigerator, not freezer. Sometimes it gets just could enough inside the refrigerator section near the bottom to freeze the line.
Could I disconnect the water line down near the bottom of the front door, blow some air up the line? See if its block, meaning its frozen? If it is frozen how would I defrost it? Do I have the temp too cold in the freezer section?
