no ice
We are getting water from the door, but the ice maker will not make ice. The lever bar will raise up and down with no problems, we have replaced the water filter, don’t see an on/off button, and water line into the frig is open, water is getting to the filter. What else could be wrong?
I am assuming that when you say the arm is going up and down, that means the icemaker is cycling. If so you have one of two problems, either the water tube that drops the water into the icemaker is froze up, or the water valve is bad. It is a triple fill valve. I do replace alot of them. The part # is 241734301. Tom http://www.applianceeducator.com/parts.htm
