No Ice
Ice maker stopped working. Noticed the gear was broken. Ordered new Motor Module AP3177342 (8201515). Replaced part and the ice maker still not working. Water dispenser in door works, however, it does not appear that water is going up to ice maker. Does not appear to have frozen line either. Any suggestions? Thank you
Open the freezer door and monitor the "status" LED on the right side.
Press in the emitter flapper door on the left side to unblock the optics beam and view the "status" LED.
Post you findings.
Husband said he had already tested that per the papers that were attached to fridge. Indicating optics were working.
Results were…two pulses followed by a delay and when emitter flapper door was pressed to unblock beam it stayed on solid.
Do you think we should have ordered the complete ice maker rather then the Motor Module?
Thank you for your assistance.
