no lights in refreg
have no lights in freg work in frezer unit shuts off now and then no numbers on temp control is it the control board model GS6SHEXNS00
Replace the bulb,PUT ON A GLOVE AND TIGHTEN IT TIGHT!!!:slight_smile:
If you pull the refrigerator out, and take the back bottom cover off, and next to the compressor is a white box, held in place by 2 screws. Unscrew the 2 screws and pull the box out, and inside is a electronic control board. Pull it out, and you will most likely see a burn’t spot in the back. The part # is W10135090. Let me know what you find. Tom http://www.applianceeducator.com
