No Power
Howdy,
My front loader will not run. No lights, won’t fill, door won’t lock… Nothing.
I have checked the power source and it is hot and the machine is plugged in.
What should I check first?
Cheers,
Sparky
Hi Sparky
Even though this has GE written on the machine this is a Frigidaire made washer with a GE label.
If you are sure you are getting power to the machine, use a meter to see if you are getting power to the timer (you may have to trace some wiring) and if so then I suggest changing out the timer.
Thanks sidfink43,
After removing the top and staring at it for 5 minutes it "fixed" itself.
Cheers,
Sparky
Man you have a powerful stare. Great, glad you got it fixed.
