No power
I have a Maytag front load washer barely over a year old and it has no power. There is power at the outlet and coming into the machine but when the power button is pushed nothing happens. No lights, no error codes, no sounds, nothing! What should we check first? :confused:
Check all your power connectors, just unplug, then plug in. You can also use non-residue contact cleaner on all the connectors.
On my Frigidaire range, error F11 shows on the timer screen and the beeper sounds. The control panel does not respond. Oven and range top do not ignite. Re booting results in same error message and the control panel is still non responsive. Do I have to replace the timer unit? Is this a simple repair?
