No Power
My washer shows no sign of power,the timer will not run any cycles and will not fill with water,any suggestions?:frowning:
Check for continuity between the "L1" & "SW" terminals on the lid switch (#3 on the [AP3159413](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=655601&&model_id=48140"]break down diagram[/URL]). Replace the lid switch if the circuit is open.
Here are the break down diagrams for the Maytag Atlantis washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=672747&&model_id=48140
I’m glad you were able to fix it. Happy Holidays!
