Filled up with water then power went no lights will come on even light bulb won’t turn on by passed lid switch and still no power
Unplug the machine for at least 15 minutes. Will it power up once plugged back in? Do you have a meter to test voltage with?
Left unplug all night and plugged back up still no power and I do have a volt reader jus not sure what to check mine has electronic buttons no knobs at all
If you can verify there is power to the outlet, the main machine control is likely faulty. You can follow the main power in and verify voltage to the control which would verify board failure. Let me know what you find for voltage. If that board is bad, it is no longer available.
