Kenmore Elite Washer Dead
Hello, my Kenmore toploading washer is dead. It has a touch pad controls but nothing lights up. I have replaced the controller since it had previously become faulty and had the same symptoms but still nothing works. I tested the touch pads and they seem to be okay but I’m not 100% sure. There’s power going to the controller according to my voltage meter. Is there anything obvious I should be looking for? Thanks for any advice. Bob
If power is getting to the control board and it is not lighting up it is likely the board is bad.
If you purchased the replacement one recently contact the selling company and see if it is under warranty and if so get a replacement.
Thanks. That’s what I suspect, too. I’ve got Sears coming in to check things out in a week since I bought the part from them.
Bob
Good, let us know how it turns out.
Hello all, This morning the water would not come out of the door. After reading some stuff on GE’s website I checked the coil and it seemed frozen. Made some adjustments and left for work. Got home and noticed water dripping from the dispensor and opened the freezer to find that everything on the upper half was defrosting including the ice. I emptied everything but noticed that everything on the bottom was rock solid. I also noticed that the fan in the back was not working. Could this be causing this issue? Just before i decided to type this, I checked on the freezer and i heard what sounded like water dripping on a hot exaust and the back panel was warm tothe touch which had very small ice dropplets on it before. Any ideas?
Also the fridge seems to be working fine but should I keep it on or will I burn something up?
Thanks in advance for any help and sorry for the long post!
