Wife indicates cloths were wet at end of cycle. I set it at a low water setting and then try the spin on normal cycle. Water drains fine. No spin. Try the permanent press cycle. No spin. I move the basket with my hand and it starts going by itself. Spin is kind of slow and I can stop the basket with my fingers but it continues once I release the pressure. I try the normal cycle spin again. Works fine. Try the permanent press. Works fine. In both cases I can’t stop it with finger pressure. Haven’t tried with a load of clothes yet. Is this a symptom of the brake sticking or a clutch problem?
Related topics
Spin cycle | 1 | 688 | March 16, 2009 | |
Whirlpool Washer | 0 | 991 | February 7, 2009 | |
not spinning | 2 | 1214 | July 15, 2008 | |
Tub needs help to start spinning | 1 | 1061 | June 13, 2009 | |
washer does not spin | 2 | 891 | August 6, 2009 |
