Hi guys! This whirpool washer gets no cold water.I initially thought that only on rinse cycle but when i selected cold water only on initial wash cycle, water barely came out. When I selected "Warm-Cold" option, water came out obviously in main wash cycle but not on rinse cycle. I opened it up and checked the voltage to water inlet valve, it’s getting 120v in the rinse mode… any suggestions? Thanks
The problem can be a clogged screen inside the water valve or a bad water valve itself. I would recommend to replace the water valve because the part is no expensive and will make the repair more reliable.
- The water valve [part]285805[/part]
The model number you posted does not come up. The closest model number I found is LSR6132EQ1.
Gene thanks the reply, I’v replaced the valve and it’s working fine.
You are welcome. I’m glad it’s up and running.
