Whirpool Washer Will No Go To Rinse Cycle
I have a roper/whirlpool 4 cycle washer.It works great through all wash cycles,fills-aggitates,drains and spins,but will not start the rinse cycle on any of the wash options.Does not begin to fill,etc. Timer is silent-no noise-no nada.
thanks
Hi.
Most likely the rinse cycle is set for cold water only. Check if you are getting cold water to the washer, then check the water valve. If it’s getting 120VAC to the solenoid - replace it 285805
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=266281
Post the results.
Simon.
Thanks I’ll Check Into It
Thanks Simon / APP Team,
You gave me the solution to the problem I was having with my washer
You took a load off my shoulders
Take care :wink:
You are welcome.
Simon.
